JaxDad
Nov 13, 2017Explorer III
lordnorth wrote:
I might have to give the compressor a try. Everyone talks about pressure, bot not necessarily volume. How much volume do I need to push through to make it work...?
I have a little 12 volt tire inflator that goes to 120psi... but I'm sure doesn't have the volume to make a difference.
-Chris
You need BOTH pressure and volume of air. One without the other is useless.
The pressure is what does the work of moving the water, the volume is what keeps it moving.
Every time I see some one talking about blowing out lines with some little bargain store compressor with a tiny tank I think ‘man they are going to be lucky if they don’t have a major issue after that!’.
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Sep 03, 2026
