We_Cant_Wait
Dec 07, 2014Explorer
When I did ours (Sounds the same as yours) I used air to clear the lines first, then pumped pink stuff thru the water dispenser and made slushy ice cubes. One note though the water filter in the fridge WILL remove the pink color from the Antifreeze so I would take a slight taste to ensure that the antifreeze was fully thru the system. Then in the spring I'll run fresh water thru the system, make a couple batches of ice cubes, and then replace the filter. I'll keep the old filter and mark it ANTIFREEZE and then be able to reuse it again the next fall.
Having RV issues? Connect with others who have been in your shoes.24,391 PostsLatest Activity: Jun 07, 2026
