smcrea's avatar
smcrea
Explorer II
Sep 21, 2017
Winterizing a Trailer Procedure
Hi,
Sorry if this subject has been thrashed out previously.
I've just moved from San Diego to Frederich MD and have never winterized my trailer before.
Could someone please give me a step by step procedure along with required tools to do the job?
Thanks!
Steve.
  • If this is your first time winterizing, there are two ways you can go about doing it, or use a combination of both. Folks use both and neither is right or wrong.
    First, there is the “blow” method.
    Cons: Although blowing the lines of all water with compressed air, there could still be fine particles of water droplets left behind, especially in the valves of the faucets. These can still freeze. Although everyone who uses the “blow” method says this doesn’t happen, there is still water moisture in the lines, and that will freeze, although may not be enough water to expand enough to hurt anything.
    Second, there is the “pump the pink” method.
    Cons: “Pumping the Pink” means you are pumping RV (Pink) potable drinking antifreeze through your water lines, which will replace every bit of water and replace with the RV antifreeze. This leaves a taste in your water lines that most people don’t like after the lines are flushed out in the spring and replaced with normal water. It means flushing your lines until you have no more taste and your water runs clear from the faucets. It always clears up, it just takes a little water to flush everything out.
    With the “Pump the Pink” method, you do not want to get any of the “pink stuff” in the water heater. It won’t hurt the water heater, but it is challenging to flush out the water heater in the Spring to get all the “pink” out. Otherwise, your hot water will have foamy bubbles in it for a long time, until it finally rinses out with normal use. Here again, it doesn’t hurt your water system, it’s just unpleasant for some people.
    So make sure your water heater is in “by-pass” before running “pink stuff” AND before using the “blow” method.
    And, for the same reason, you don’t want “pink stuff” in your fresh water tank. It’s just WAY too difficult to flush it out in the Spring.
    Combination of both?
    Some folks blow the lines first, then run the antifreeze.
    Some folks run the antifreeze first, then blow out the antifreeze. (I do this).
    Note: RV antifreeze will freeze up (or turn to a thick jell) when temps get below 10 degrees (F) or so. This is perfectly normal and does not hurt anything. The liquid may appear to be freezing up, but it does not expand. That’s how it’s suppose to work.
    Note: If you use either method or a combination of both, remember to get your outside shower and / or outside kitchen sink (if you have one), and remember to open the low point drains and let any water be displaced with either air or “pink stuff”.
    Pumping the pink is relatively easy. You disconnect the “In” line going to your fresh water on-board water pump. You attach another hose. Some campers are already equipped with this, (called a winterizing kit, where you just flip a valve between the external hose and the on-board fresh water tank). Insert the hose into a gallon jug of the “pink stuff”, then turn on your water pump. Let the pump run until it reaches pressure and shuts off. The simply go to each faucet one at a time, hot and cold, and run water until it turns pink. Remember the toilet too. Then last, crack open the low point drains under the camper until they run “pink” too. You should be able to do this with 2 gallons of “pink stuff”. But for the first 5 years of my RV ownership, I made sure I had 4 gallons on hand. The first year I did this, I used all 4 gallons, because I kept running much more pink than was really necessary.
    Since then, I’ve got it down to 2 gallons. I like to blow the lines when done, so the pink stuff will go down the drains and help protect the P-traps under the sinks and shower drain.
    If you use the compressor “blow” method, you’ll need an attachment that screws into your fresh water (city inlet), where you attach a garden hose too. The attachment looks like a valve stem on your car tires, except its either hard plastic or metal.
    Using an air compressor, pump the lines with pressure, then have some turn on each faucet, hot and cold, until it spits no more water. When I do this, it takes 2 people: One to hold the air compressor on at that valve stem, and the other to turn the faucets on and off one at a time. There is a risk using the “blow” method, if you put too much air pressure in the lines, you could blow up a line or a connection somewhere. So make sure when you start pumping the air, you regulate the max pressure for the air compressor, somewhere around 50 psi, so you won’t over-pressurize to push the water out.
    There are dozens and dozens of YouTube videos explain and showing how to do both methods. Check them out. In the search box, just type “Winterizing RV” sit back, and enjoy! After you’ve done it the first time, it will be old hat for you, and next year, you’ll be answering another poster on these forums how to do it!
    Good luck.
  • I agree that pumping antifreeze through the system is a good idea however, as we camp year around, I'd go through too much of the stuff for it to be cost effective for us. Most motorhomes are capable of very cold weather use with all the plumbing installed in 'conditioned space' while some trailers that aren't considered 'arctic ready' may have external plumbing that can freeze up even when the furnace is running. Sometimes determining that can be tricky.
  • DrewE's avatar
    DrewE
    Explorer III
    Others have pretty well covered it.
    If you have neither an air compressor available to blow the lines out with (at relatively low pressures) nor a winterize inlet port to pump antifreeze in, you can also pump antifreeze by putting some in the previously emptied fresh water tank and pumping it around from there. That's not the preferred method--it takes a good bit more antifreeze, and equally more work to clean it out in the spring--but on a few trailers it's about the only way they make a provision for.
    If you have a washing machine, consult its instructions for proper winterizing. If you have a water filter spigot on the kitchen sink or something similar, typically they need to be removed/disassembled and the housing drained.
    Don't also neglect to remove foods (that attract critters) and water-based cleaning products etc. that can freeze and burst their containers.
  • I pump two gallons of antifreeze when I winterize as mike-s describes. Do not forget your outside shower if you have one, I got dinged by that once and had to replace the entire busted apart assembly. I always put a little of the antifreeze in the toilet also, I have a phobia about the seal drying out...
  • The best tool to own is a battery powered compressor with a regulator you can set at 40 lbs. You don't want to over pressurize the system. You can get a fitting that will screw onto your water hookup that will let you connect your compressor there. Find the bypass valve on your water heater and close it. Remove the drain plug on the water heater and let it drain. With the compressor running, go around opening all the faucets (hot and cold) one at a time on sinks and shower and open the toilet valve. Go around and around a few times until all you get is air coming out. If your fridge has an icemaker, unscrew the water line for that at the valve. when no more water comes out anywhere, you are almost done. You will need a gallon of RV anti-freeze to pour a little in the sink and shower traps. Of course you should also have emptied the black and grey tanks, too. As the other poster mentioned, you can also use the RV water pump to pump the antifreeze through the system but if you blow it out good, that's not necessary.
  • Drain all the tanks. Bypass the water heater and drain it, which also gives you an opportunity to check the anode rod. Blow out the lines, or pump RV (pink, non-toxic) antifreeze through them, opening everything (faucets, showers, toilet) until it comes out pink. There's often an open line ahead of the pump for that which you can stick into a bottle of antifreeze (close the valve to the fresh tank, open the valve for the hose). Pour some antifreeze down each drain.
    If you don't have solar, or won't be plugged in, take the battery home and charge it one or twice during the winter.
    I'm sure there are guides, including video if that floats your boat. Google is your friend.
