wa8yxm
Jan 08, 2019Explorer III
SFVdave wrote:
Can I wire a 2000 watt inverter to my existing transfer switch so I can use existing outlets while dry camping without the generator. My battery bank will be a bank of 2 12v Lithiums 100amp each. Not going to be a lot of draw. Currently using a 400 watt for my Dish receiver without any issues. DW wants to know if she could use her hair dryer of 1200 watts for 5 minutes too?
in theory yes in practice I would not
I have a freedom 2000 XC and a Prosine 2.0 and there are a long long long list of others that are like these.. NO TRANSFER SWITCH NEEDED with these devices though a sub panel may be needed.. I will explain
When the Prosine (now failed) was added to the RV what they did was run two lengths of 10Ga Romex one from a 30 amp breaker in the breaker box TO the Prosine (And not the Freedom XC) and the other FROM the Prosine (And now Freedom) to a SUB panel (A 2nd breaker box) They then transfered 3 circuits fromn the main panel to the sub panel
MIcrowave
GFCI
TV/Electronics
Now this did NOT include the outlets by the bed (The Fridge is on that line so they did not include it) I have since added a manual transfer to put that on the same breaker as the GFCI if I need bed power but since I have to manually transfer I lock the fridge on Gas.
How it works.. Normally (I'm odd)
Shore or generator power present the Inverter/Charger charges batteries and PASSES power to the sub panel and from there to outlets and stuff.
Should Shore/Generator become absent.. The inverter instantly switches over in the manner (in my case) of a UPS the TV"s and computers do not even blink the switch over is that fast (On the Prosine that is default. on the Freedom it's an option).
Thus my Factory Transfer switch.. Is not involved in the inverter switching. Freedom XC 2000 is less than 1000 dollars Only issue is I did not like the 120 volt connections They were a pain
Having RV issues? Connect with others who have been in your shoes.24,397 PostsLatest Activity: Jan 16, 2025
