theoldwizard1
Jan 08, 2019Explorer II
DrewE wrote:
The transfer switch will select between two inputs. It can't select between three inputs.
Actually, not exactly true !
Some inverter/charger with built in transfer switch, like one of these Samlex units, will select 1 of 3 different inputs, shore power (grid), generator or battery (inverter).
These are actually very easy to install with all connections in one place.
You no longer need a converter ! Simply wire the the DC fuse panel directly to the house battery bank (via a fuse, of course).
Your wife CAN run her hair dryer, especially if you have Lithium batteries, but it may mean you will not have as much energy to run other appliances.
Having RV issues? Connect with others who have been in your shoes.24,397 PostsLatest Activity: Jan 16, 2025
