MrWizard
Jan 09, 2019Moderator
Boondocking, put fridge on propane and leave it there, it uses so little l.p., there is no need to switch back and forth with electric,
Microwave on half power, I doubt it, most used timed cycles, power on and off, when cooking at reduced power, so still use full power for half time
That's what mine does, and it's a Panasonic (supposed inverter MW)
I measured the power use with 3 different meters
Hair dryer on low, yes that's a heating element, and will work that way
Provided you have enough battery, for the run time needed
Use good 12ga or heavier extension cord, for the inverter out put
Having RV issues? Connect with others who have been in your shoes.24,397 PostsLatest Activity: Jan 16, 2025
