SFVdave's avatar
SFVdave
Wire inverter to existing transfer switch or need another?
Can I wire a 2000 watt inverter to my existing transfer switch so I can use existing outlets while dry camping without the generator. My battery bank will be a bank of 2 12v Lithiums 100amp each. Not going to be a lot of draw. Currently using a 400 watt for my Dish receiver without any issues. DW wants to know if she could use her hair dryer of 1200 watts for 5 minutes too?
  • I've not dealt with that situation so I better defer to others on the xfer switch. I'd be looking to get an inverter with the switch in it, and wire that up after the existing switch and before the panel.
    Those Li's should handle the hair dryer just fine without much voltage sag. Just be sure the 12v wires are big enough. I encourage folks to go to 24v for more extensive high-draw use, but that doesn't sound like your case.
Having RV issues? Connect with others who have been in your shoes.24,371 PostsLatest Activity: Mar 21, 2026
