RoyB
Sep 06, 2016Explorer III
I have my duty 600WATT PSW AIMS Power Inverter wired as close as I can get to my main battery switch. It has 4AWG cables feeding the Power Inverter and runs great. Actually it is ON most of the time even when I am at electric sites... The low power drain is very minimal for me when noting is turned ON using the Power Inverter.
What I did was run two of these multihead 120VAc extension cord drops and mounted to the back of my Home entertainment area which would also be close enough to my kitchen top area as well...
This is what my multi-tap extension cord looks like... It is neat in that it has an ON-OFF switch on it as well... It also has two screw down tabs on both ends... You can't see any of the extension cord as it is run behind things and plugs into the Power Inverter 120V receptacle under a storage cabinet.
google image
I ran a second like extension cord back to the cabinet close to the tent bed we sleep in all the time. This is my always ON and available 120VAC Power to run things like cell phone charger-computer chargers, lamp and fan etc... I may have grabbed the wrong photo from GOOGLE Images as mine has a ON-OFF switch on it but you can get the idea here...
This would way easier to do than to split out a standard RV 120VAC receptacle. The RV receptacles are also very cheap made and uses the compression backs that pinches the wires that feed them. It has been my luck that everytime I remove one for whatever reason I also break my wiring where it has been pinched. There is never any slack in the wiring so it suddenly becomes a bigger project. If it was me I wouldn't touch those thin line style RV receptacles if I didn't have to...
I also have a PSW type Power Inverter and this solves the problem of who might plug something into the emergency power socket and it burns it up. There are many things that one should never plug into a cheap made MSW type Power Inverter. An electric blanket controller will start pouring out the infamous BLUE SMOKE before you plug it into a MSW Power Inverter. It knows what it is going to happen before you plug it in haha... Almost anything Electronic or that has transformers or motors does not like the MSW Power Inverter. No good reason anymore to take the chances... That was the first thing I burned up and the second thing was a 20-inch box fan running to keep the mosquitoes off of us sitting around the camp fire.
The only thing I still use with my old MSW Inverters that are still working is outside lightning.
My home entertainment items doesn't know the different between the shore power/generator connections or my PSW Power Inverter...
Roy Ken
google image
Roy Ken
Having RV issues? Connect with others who have been in your shoes.24,398 PostsLatest Activity: Jul 02, 2026
