lawrosa
Mar 19, 2018Explorer
My crude drawing.. I can only plug into the pedestal, of the TT/30 amp plug I mounted under RV to inverter. I can never connect two power sources...
That's a typo that I lifted the ground wire in the TT 30 amp... I was going to for safety but not needed because the TT have a floating neutral and is not tied to ground...
And a good inverter to get with open nuetral are these kriegers. No GFI. Cheap and a 3 year warranty.
Keep it close to the batts. No reason to use more then the 1100 watt unit. Becuse if you drew close to 1000 watts for a appliance that would be 90 amps..
Run 2 gauge or better and try to keep it close, like 7 ft or less from batts.
http://www.kriegermfg.com/products/power-inverters/
89 bucks. Cant beat it...
I used their fuse but ran my own 2 gauge wire... ( I think the wire they supply is aluminum... not sure)
https://www.amazon.com/Inverter-Installation-included-Automotive-according/dp/B00T564EIY
