westend
Jul 07, 2014Explorer
pigman1 wrote:I used this LB because I piped the 4 AWG from this box down to the controller. A 4" plastic box would have been easier to use.
You can do a lot better than $80 for a combiner box. Buy a 5 or 6" square PVC box at Lowes or Home Depot and add an extra top. Cut the PVC top to separate the box into 2 compartments and add 2 small ground bars, one for pos and one for neg. When your feeds come in from individual panels, splice a small flat fuse into each line and individual panels will be protected. I dropped the main feed to the controlled directly out the bottom ans sealed the box to the roof.
A bit of work can save a lot of $$$. Just take your time and keep your options open.
Having RV issues? Connect with others who have been in your shoes.24,329 PostsLatest Activity: Oct 28, 2025
