Almot
Jul 07, 2014Explorer III
pigman1 wrote:
You can do a lot better than $80 for a combiner box. Buy a 5 or 6" square PVC box at Lowes or Home Depot and add an extra top
Yes. This was exactly what I was going to do before decided just to run series #10, following the steps of Smkettner and others. Easy, no box.
And, there are grey PVC waterproof boxes in the same Home Depot with top and gasket included. 4x4x2" or 4x4x4", cost $6 or so. I even bought one and immersion-tested in in a sink, it is waterproof indeed. Click on the link by Renoman69's in the middle of the list, there is this box on the roof and another one inside.
Luckily, I didn't need rooftop box with series wiring, and the OP also can "cheat" here with his parallel, here is how:
You have those MC4 Y-splitters included with 140W pairs. Buy MC4 cable #8, say, 40ft (see my link few posts above). Cut it in half and run from Y-splitters to inside, using strain reliefs on fridge vent or any cable grips - NOT important, on the vent it isn't a watertight seal anyway. Then install one PVC junction box inside, and run #6 from there. As estimated above, 35ft #8 is enough or very close. So, 17ft of #8 plus 17ft of #6 will be acceptable. No roof J-box. I don't like roof J-boxes. If left for summer in Mexico, this gray PVC would become white and brittle, don't know how waterproof the lid will be then.
I posted the link to the entire List of installs, because the very 1st link by Sleepy shows the above mentioned AM Solar $60 J-box for fridge vent, if you still want a roof J-box. Note how vent cover is bulging with this J-box.
Having RV issues? Connect with others who have been in your shoes.24,329 PostsLatest Activity: Oct 28, 2025
