MEXICOWANDERER
Apr 12, 2016Explorer
I wish I could read Chinglish without getting seasick...something in there about optional separate modules but I am far from my Dramamine...
Product Description
Features:
1.12V 2A-10A learning code receiver /switch with suicase cover + transmitter /remote control
2.You can turn on or turn off the receiver with transmitter(remote control) from any place within a reliable distance
3.The wireless signal can pass through walls, floors and doors
4.Receiver Sensitivity: -100dBm
5.Encoding Type: learning code
6.It uses fixed coding, stable and reliable
7.Operating Frequency: 315 MHz/433MHZ(here is in set work together .you don't have to care what frequency are they)
8.The output way is adjusted between Jog/inter-lock /self-lock
Learning and remove method:
1. Press the learning code. the indicator flash, loosen your finger, press any button of the remote control, the indicator flash 2 times and off. it mean you learn it successfully.
2. It can learn more than 12 PCS 2262 or 1527 chip with the different code wireless remote control.
3. Remove/clean: press the learning button about 8 seconds, the indicator turn on to off, it means the information that you keep have been removed successfully.
Package Included:
1 x Transmitter (with battery and key ring)
1 x Receiver (with the cover)
Seller Warranty Description
Long term warranty 30 day for replacement
Product Description
Features:
Package Included:
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Mar 09, 2026
