dougrainer
Dec 20, 2020Nomad
Teleman wrote:ktmrfs wrote:
here is one option. not inexpensive, but it really does work well, at least with our coleman, and it is designed to work with dometic as well.
https://www.microair.net/products/easytouch-rv-thermostat?variant=32199143555156
nice features include the ability to choose or switch heat source from gas furnace to heatpump/heating coil, easy to change between high/low fan, setback etc.
That's more than I need, or want to spend. I'm looking for my furnace only but I appreciate the response!
You will NOT find anything sub $250 for a 20 year old system. This Micro air will not work with a 20 year old Dometic control system. Even the out of stock Dometic $95 will not work with your 20 year old system. You will have to spend hundreds of dollars to upgrade the Dometic Electronics AC/Furnace packages to make any remote system work. Doug
