MEXICOWANDERER wrote:
Do whatever it takes to find larger wire size PACKARD female terminals. They have a ramp tang inside that increases conductive area contact surface.
I've not seen anything larger than 10-12 gauge Packard terminals and they are never encased. Always bare. With care solder 10 gauge AWG wire to the inside tang then crimp the top tang to the wire insulator. I cover with 3:1 heat shrink tubing.
When I built the BORG I soldered 3 into 1 wires directly to the terminal block screws and all.
Thanks Mex, will look for Packards and try splitting the 6ga wire in two to mount the Packards.
