familyof3's avatar
familyof3
Witch Magnum Inverter?
New to the power inverter's. Looking at the 3000 Watt Magnum Hybrid and the 2800 Watt Magnum. From my understanding the Hybrid will have a 240 Volt output and the 2800 Watt puts out 120 Volt. I only have 4 6 Volt batteries and looking to add 4 more 6 Volt batteries to my battery bank. Any help would be appreciated about on this.
  • Do you need 3000 watts of 120 volt power? Or even 2800?
    Eight batteries at 65 pounds each is 520 pounds? That’s a load of batteries.
    To get 3000 watts from 12 volt batteries you pull 250 amps.
    Even eight batteries won’t supply that for long.
  • The main advantage of the hybrid unit is it's ability to operate in parallel with your generator. This can allow a smaller generator to start you air conditioner, for instance.
Having RV issues? Connect with others who have been in your shoes.24,337 PostsLatest Activity: Nov 21, 2025
