CA_Traveler
Aug 22, 2021Explorer III
The PV + wire connects to the controller PV + terminal. The PV - wire connects to the - battery terminal, The small controller black wire is for the electronics only and not used for the - charging circuit.
The PV green wire could be a PV frame ground or something else. Veryify that it's actually charging with a ammeter and there is a - negative PV to battery post wire.
Having RV issues? Connect with others who have been in your shoes.24,413 PostsLatest Activity: Sep 14, 2026
