BFL13
Aug 22, 2021Explorer II
CA Traveler wrote:
The PV + wire connects to the controller PV + terminal. The PV - wire connects to the - battery terminal
If "PV" means "array", then the "PV - " wire would go to the controller's neg input terminal ("array neg" on some controllers) not to the battery
The small controller black wire is for the electronics only and not used for the - charging circuit.
The PV green wire could be a PV frame ground or something else. Veryify that it's actually charging with a ammeter and there is a - negative PV to battery post wire.
Very confusing to use "PV" instead of "array" and "battery" for the input and output.
Having RV issues? Connect with others who have been in your shoes.24,413 PostsLatest Activity: Sep 14, 2026
