CA_Traveler
Aug 22, 2021Explorer III
Good point about terminology but I was using the OPs terminology.
If "PV" means "array", then the "PV - " wire would go to the controller's neg input terminal ("array neg" on some controllers) not to the battery
This controller does not have a PV/array - input. The - PV wire goes to the - battery terminal, I know different. I'd want to know what the PV green wire is that's connected to the + battery post UNLESS as the OP suggested it is really from the panel which is why I asked if the solar is really working.
Having RV issues? Connect with others who have been in your shoes.24,413 PostsLatest Activity: Sep 14, 2026
