CA_Traveler
Aug 22, 2021Explorer III
Check the panel Voc (open circuit), Isc (short circuit) to verify the panel is OK. With the panel and with the panel - wire corrected measure the controller + amps to the battery with a discharged battery. I'll bet a dounut that you'll find everything OK and you've not had prior solar charging.
Having RV issues? Connect with others who have been in your shoes.24,413 PostsLatest Activity: Sep 14, 2026
