CRMW's avatar
CRMW
Wood hole - Water damage
I am dealing with an anchor in the roof that wasn't sealed properly. Water damaged the area around the hole but seems to be only 1/4" to 1/2" I am wondering if i need to remove the damaged (damp) wood or can I just seal the holes with Eternabond?
Chris
  • Take the time and do it right. It will be easier in the long run.
  • agesilaus wrote:
    I'd clean it out to good wood and patch that area with epoxy putty then use eternabond.
    X2. Leaving the damaged wood in there would be like leave a little rot on an apple. Eventually it's going to cause more problems.
  • I'd clean it out to good wood and patch that area with epoxy putty then use eternabond.
Having RV issues? Connect with others who have been in your shoes.24,323 PostsLatest Activity: Oct 05, 2025
