Woodtroll's avatar
Woodtroll
Worthwhile to change out my Parallax 7300 Converter/Charger?
Hello folks,
For years I have read that the factory converter/chargers on most RVs don't usually charge the storage batteries very well. With tax returns I finally have a little money to change out my power unit if I decide to, but I am wondering if it is worthwhile?
We often camp where there are at least electrical hookups, but frequently boondock, and for that I have solar panels run through a charger control that works well. At home between trips, I maintain the batteries with a Xantrex SureCharge 10 that has three different charging levels along with a periodic high charge to keep the plates clean. My batteries consist of one deep-cycle group 27 12-volt that we usually use while on shore power, and two 6-volt GC-2s that we use off the grid. I seldom have to add water to either, maybe a little bit twice a year or so.
I was considering changing out my OEM Parallax 7345 for a Progressive Industries PD4645; it is pretty much a direct replacement for the charger portion of my power center that has multiple battery charging levels, an charge level indicator light with an override switch for manual mode, and comes with a new DC fuse panel that has the "blown fuse" indicator lights, all for about $200. However, while researching my options, I ran across some information on Parallax's website that made sense. They said basically that the variable-rate chargers with the high-voltage modes work well for batteries, but when they also supply power to the trailer lights and accessories on the same outputs as the battery charger (as the PD4645 does), there is no "buffer" to deliver more consistent voltage to the trailer itself, meaning that some appliances will be subjected to higher voltage at times. I had wondered about this myself, but had never seen it in writing before.
So, really, I have no need for the faster recharging times that the Progressive Industries unit can provide, since I have a charger especially for the batteries at home and don't use a generator while boondocking. The only advantage I can see at this point to changing the module out is possibly(?) longer battery life, and the blown fuse indicators that I don't have now.
I'd value your input and experience- would I be wasting money to fix something that doesn't seem to be too badly broken, or will my much longer battery life eventually pay for this upgrade? Are there any other pieces to this puzzle that I am missing?
Thanks, safe travels!
Regan
  • My original reason for keeping the 7355 was that it was miles from the batts on wiring too difficult to change, so anything going in its place would be just as bad from voltage drop on those wires.
    Once the solution was seen to be to use a deck mount converter or charger up front close to the batteries to get short/fat wiring, there was no need to replace the 7355. I have had a variety of fast chargers up front, but the 7355 keeps chugging along doing its job whenever I have shore power.
    When generator charging, I like to disconnect the batts, run the rig with the 7355, and use the fast charger(s) on the batts. This means there is no draw on the batts while I am trying to charge them at the same time.
  • I swapped out a perfectly good 7355 for a PDI9260 and I'm very happy I did. I no longer have to worry about the converter overcharging my batts and it re-charges faster as well.
  • smkettner wrote:
    I would sooner spend the money on an additional solar panel or tuck the money into an IRA.
    Would seem that you have very little need to replace the 7345.
    Even by some miracle the 7345 quit you could still camp fine with the Xantrex.
    X2
  • I had a 55 amp Parallax unit. In my case it was bad and needed replacement. The transformer and several resistor were bad. After searching and pricing I decided to replace it with the PD 9260. The price was less and the reviews better.
    I have left my unit plugged in at home for extended period while checking voltage and water levels. At present it's been installed for about 9 months. I've added water twice in the period of time. I had to modify my installation because of a angled brace behind my power box. I ended up turning the entire box upside down so the PD unit was above the brace. The converter is now above the fuses.
    I'm very satisfied with the swap.
  • RoyB's avatar
    RoyB
    Explorer II
    The problem I have here in Northern Neck Virginia is most camp grounds we go to all seem to have generator run time restrictions in place... Most are 8AM to 10AM and then again from 4:30PM to 7:30PM. Even the Natl Forest sites close by have these same restrictions in place. Occasionally we will find a Natl Forest site with generators allowed from 8Am to 8PM. No public location we go to here can we run our generator after 8PM at night.
    With this in place we have to use smart mode charging units to be able to get our batteries re-charged back to their 90% charge state in the three hour time frame...
    I have to start each day/night run off the power grid with at least a 90% charge state otherwise it will get dark on us around 10PM each night.
    For me this is the only reason that we changed out our older single mode converter/charger for the smart mode fast charge units. I use the PD9260C converter/charger here and at 8AM each morning we have our trailer shore power cable hooked up to our 2KW Honda generator purring away.
    Most public places we camp at here on the East side of the USA have these same generator run time restrictions in place.
    Roy Ken
  • I would sooner spend the money on an additional solar panel or tuck the money into an IRA.
  • Similar situation here. Nothing wrong with our ten-year old 7355 and it is fine as a converter on shore power. I use a different charger for fast charging off-grid and a different float charger at home too if temperatures get too hot for the 13.8v float of the 7355. No reason at all to swap out the perfectly good 7355.
    There are so many other neat RV toys to get, I agree it would be a waste of money to replace your 7300. :)
Having RV issues? Connect with others who have been in your shoes.24,337 PostsLatest Activity: Nov 21, 2025
