MrWizard
Nov 21, 2018Moderator
its normally stored away, i keep it as a tester, normally for A/C season
i hooked it up for this test, will leave it in place and maybe get a 'high' amps reading thurs or fri
i have seen the converter charge meter, read 80 amps
maybe i can get a power meter reading, with an 80amp charge reading
one more test you might try
do the MW/inverter operation test
then turn off the inverter while leaving the genny and converter on
see if it stays running and what the load is
Having RV issues? Connect with others who have been in your shoes.24,403 PostsLatest Activity: Aug 02, 2026
