BFL13
Nov 21, 2018Explorer II
Interesting how with the same 75 amp converter/charger you get a better PF at 0.79 than I do at 0.7ish. Your efficiency percentage is the same at about 78%.
Your loaded voltage is lower than what I got 114 vs my 118 , but that depends on the generator. When on the Honda 3000, I got a higher loaded voltage than with this little guy because the Honda unloaded was 126.8v while this one is 124 so loaded voltage is lower too.
Another thing on that is the Honda 3000 dropped from 127 to 124 , 3 volts while this little gen went from 124 to 118 , 6 volts when hit by the same 75 amper.
Must have something to do with the size of the engine wrt the "120v" output.
Anyway, just noting that all generators are not created equal in how they handle a particular charger
Having RV issues? Connect with others who have been in your shoes.24,404 PostsLatest Activity: Aug 06, 2026
