BFL13
Nov 22, 2018Explorer II
MrWizard wrote:
that flashing light, says don't add anymore load :)
individual item efficiency, only means something, IF there is a way to improve it
over all Efficiency is the end result of the assembled system
and we are not that far apart 0.5% the use of different meters and batteries can account for that easily, or even the mfg tolerances of the parts in the converter
Yes, it all comes out even when you use your "gross efficiency" idea.
So do you think that red flashing light is like the "low voltage alarm" on an inverter, where the inverter keeps running until the voltage gets even lower and the inverter shuts off the 120v ?
EDIT easy to ignore the gen one when there is no noise maker along with the red flashing light! :)
Thanks Gdetrailer, good info and suggestions.
