BFL13
Nov 28, 2018Explorer II
MEXICOWANDERER wrote:
You are not dealing with a fixed resistor. But a reactive electro chemical response.
Look up
Charge
Efficiency
Factor
Why should the converter care how many of its output amps are going to heat and how many are going to raise battery SOC? I am thinking the converter needs the same 120v input power.
OTOH, I still have that problem where it pulls less power when doing its 75 amps while "supplying" than when battery charging. I suppose that is because of less resistance when supplying.
It is also when battery voltage is quite low while being pulled down by the inverter running the MW while the charger helps put amps in at the same time.
I need to do a standard 50-80 recharge and see if the gen has to supply as much to the converter at 50% as it does at 70% SOC.
Having RV issues? Connect with others who have been in your shoes.24,413 PostsLatest Activity: Aug 12, 2013
