MrWizard
Nov 28, 2018Moderator
I need to do a standard 50-80 recharge and see if the gen has to supply as much to the converter at 50% as it does at 70% SOC.
got it backwards again
at 50%soc the battery will accept more amps and converter will be using MORE power, VA will be higher than when when SOC is 70% and the battery is accepting less amps
UNLESS the bank is so large that it can still accept (converter max amps) at 70%SOC, in which case VA will be up, watts into converter will be up because voltage to battery has risen
what size is the battery bank ?
at point does amps into bank start to drop ?
i know in my case amps drops off long before converter reaches 'set point' voltage, set point voltage is not reached until batteries are almost fully charged
Having RV issues? Connect with others who have been in your shoes.24,414 PostsLatest Activity: Sep 17, 2026
