mapguy
Aug 30, 2017Explorer
If the Mercury grease meets the requirements listed by Dexter Axlefor hub bearing service you are good to go.
Dexter grease specs and approved list is at the link:
http://www.dexteraxle.com/docs/default-source/default-document-library/light-duty-hubs-drums-and-bearings0b9b809d2ba463c18d7aff64007a4014.pdf?sfvrsn=0
Personally, I use Lucas Red-n-Tacky for wheel bearings and chassis lube, plus other general uses. Lucas Xtra grease is also a good multiple application grease.
Having RV issues? Connect with others who have been in your shoes.24,384 PostsLatest Activity: Apr 27, 2026
