albow's avatar
albow
Would Mercury Quicksilver grease work in my wheel bearings?
IT's what is currently in my grease gun and we know what a mess it is to change a non-empty cartridge. I don't know my axle brand. I have electric brakes. I assume about any type would be suitable for a short time frame if you then pushed it on out with the proper grease, but is the grease I'm considering appropriate for the long term? I have zerk fittings, not re-doing the bearings.
  • Trackrig wrote:
    Their web site doesn't say anything about using it for wheel bearings. I've found it easiest to have about three grease guns loaded with the different types of grease I use.
    Bill
    x2, stop by Horror Fright and pick up another grease squirter or two, then you're not trying to swap one grease for another through a single gun
  • What does the manufacturer recommend? If you can't determine the manufacturer, what do most recommend? This site doesn't seem to recommend use in bearings - https://p.widencdn.net/ad2kkn
  • Their web site doesn't say anything about using it for wheel bearings. I've found it easiest to have about three grease guns loaded with the different types of grease I use.
    Bill
Having RV issues? Connect with others who have been in your shoes.24,284 PostsLatest Activity: Jul 21, 2025
