BFL13
Mar 26, 2020Explorer II
Lead acid batteries can accept "full charge" well past 80% SOC
It is all about the "charging rate", which is the amps/AH of battery bank. At any charging voltage, the lower the charging rate, the higher the SOC before amps taper at the end of Bulk and VV.
Solar often has lower max amps wrt the size of the battery bank, so that makes for a low charging rate, and so the end of Bulk in the 90s for SOC.
I don't understand what possible settings you can have on a solar controller that would alter that. The battery type settings usually only change the high voltage set point, which can change the amps being accepted. Higher voltage can mean more amps at any given SOC if the solar can provide more amps. Not going to change the charging rate very much between 14.4 and 14.8 eg.
