Mobilesport's avatar
Mobilesport
Would solar be effective in the midwest?
Would a 200 watt solar panel keep a single 100ah lifepo4 charged during a midwest Iowa winter/December ?
I use about 50 ah per day , I found a online calculator that said 50ah is about .65kwh
I believe my 100ah lifepo4 is like 1kwh or 1.2 kwh
.65kwh is about 20kwh per month so maybe a 300watt panel would work??
  • Winter will be marginal. 400 watts and a second battery might be needed. Not every day is all sunny.
  • jdc1's avatar
    jdc1
    Explorer II
    If you can tilt the panel for optimal orientation, you can pick up another 10-15% of charging.
Having RV issues? Connect with others who have been in your shoes.24,320 PostsLatest Activity: Sep 20, 2025
