MNRon's avatar
MNRon
Would you plug in?
Just pulled in to CG in TX. Plugged in the Surge and got a red fault stating L1 and Nuetral reversed and/or L2 and Nuetral. Got my attention so I pulled out the DVM and found L1-N-L2 was 120v-120v-240v as expected. The issue was GND-N was 40v, and L1-GND was 80v; L2-GND was 160v.
Went to office and was told electrical was just completely redone a month ago so can't be a problem. Also stated 4sites share electrical so I could move if wanted. After checking the 8/9 other open sites I found the same issue all over the park.
Given I'm HOT and DW wants AC, dozen other campers here are plugged in and running AC fine, AND Nuetral is good it's "just" GND - I informed office and decided to plug in for night. As long as my stuff just runs L1/L2-N AND I don't have a fault I'm OK. I don't like it but we're hot...
  • Wow, that sounds like a bad situation. If it was me, I would try grounding my RV some way. Just to make sure there is no potential for a shock or electrocution.
