Our black water tank level indicates full as soon as we set up and use the toilet once. Any thoughts? Do I need to flush it out? Fill it with clean water then dump? Help!!
Your tank gauges will never be accurate. Get used to it. It doesn't take much to get electrical continuity between each sensor -- it only needs to be damp -- you don't need a solid to get continuity. As I said; get used to it because there is no solution. Nothing is wrong with your wiring. Stop worrying.
Bruce
Having RV issues? Connect with others who have been in your shoes.24,397 PostsLatest Activity: Jun 27, 2026
