Our black water tank level indicates full as soon as we set up and use the toilet once. Any thoughts? Do I need to flush it out? Fill it with clean water then dump? Help!!
I've never had the problem that the OP speaks of !
sure the accuracy of the typical (OE) gauge leaves lots to be desired (w/ only 4 levels) but it shouldn't read FULL after a single use (unless the tank is the size of a coffee can).
lots of folks abandon the minimalistic (typical OE) monitoring systems and retro fit with SeeLevel Gauges (using the original/OE wiring)
Having RV issues? Connect with others who have been in your shoes.24,397 PostsLatest Activity: Jun 27, 2026
