tmac00
Aug 02, 2014Explorer
Wrong Black Water Level
Our black water tank level indicates full as soon as we set up and use the toilet once. Any thoughts? Do I need to flush it out? Fill it with clean water then dump? Help!!
nomad297 wrote:
Your tank gauges will never be accurate. Get used to it. It doesn't take much to get electrical continuity between each sensor -- it only needs to be damp -- you don't need a solid to get continuity. As I said; get used to it because there is no solution. Nothing is wrong with your wiring. Stop worrying.
Bruce
