MEXICOWANDERER's avatar
Jun 19, 2017
Wrong Season But Great Formula...
I came across this worksheet formula that calculates HEATING BTU values and rather than lose it before next winter, decided to copy and I am going to paste it in my Word program files...
________________________________________________________________________
You can calculate the amount of BTUs required by using the following method: Measure the space’s dimension to determine cubic feet. (Length x Width x Height = Cubic Feet). Subtract the outside temperature from the desired inside temp to determine the temperature increase. If you have measured temperature in Fahrenheit, calculate the required BTUs with this formula: (Cubic Feet x Temperature Increase x .133 = Required BTUs) If you have measured temperature in Celsius, calculate the required BTUs with this formula: (Cubic Feet x Temperature Increase x .2394 = Required BTUs)
  • Perhaps per thousands of BTUs Mr. Grainer? :) I had a 44,000 BTU wall heater in a 650 square foot home (?) in the mountains that blew me out at -29F. Ceiling insulation, no wall insulation and single windows.
    Well, back to the dart board...
  • Per Suburban, you use 1 FOOT per BTU. 30 foot RV=30 BTU furnace. Doug
    Boy, that was quick:B
  • wa8yxm's avatar
    wa8yxm
    Explorer III
    Also the R factor of the walls, floors and roof/ceiling. A very incomplete formula.
    NOTE BTU's cooling.. same calculations, Including all the variables that the O/P did not include (Door, R,Factor, Amount of glass, and so on.)
  • It has been well over 50 years but I think you need to know something about air exchange. How big is the door and how often does it open.
Having RV issues? Connect with others who have been in your shoes.24,344 PostsLatest Activity: Dec 22, 2025
