dougrainer
Nov 22, 2017Nomad
1. Need Model of Xantrex unit
2. Need model to see if it is an INVERTER or an INVERTER/CHARGER
3. Your Jayco comes with a CONVERTER. You disconnect the Converter if you install an Inverter/Charger
4. The Solar Panel set up SHOULD have a Controller between the Solar panels and the Battery bank
5. Are you positive you have 2- 6 volt batteries and not 2-12 volt batteries?
6. When Dry camping, HOW do you recharge the batteries? Portable Genset? Doug
