time2roll
Nov 28, 2017Nomad
Is it this inverter? I don't see the 'SE'
Freedom Xi data sheet
Owners guide pg 25 does not show E10
E02 is over voltage at 16.7 volts. This needs to be verified on the battery but seems very odd or something else is malfunctioning. 16.7 is too high for the battery and for the RV appliances.
So just confirm nothing is hardwired to the inverter? Just plugging the tv and cell phone direct to the inverter outlet?
150 watts is maybe 8 amps into the battery 5 hours per day. Take a week or two minimum to charge that very low battery with all loads including the inverter off or disconnected. May never charge if the inverter is idling.
So you need to plug in and check the voltage on the battery. Need to know what is charging the battery and possibly exceeding 16.7 volts. I assume it has a converter.
