time2roll
Nov 28, 2017Nomad
Freedom HFS makes more sense. E10 indicates voltage above 15.5 that needs to be verified with a meter.
E04 over temp shutdown could be poor ventilation but probably overload and explain why the batteries did not last long. Inverter is powering something large... possibly the converter. Need to verify or disconnect. Converter came with the RV and should be found near or in the main breaker/fuse panel.
8 amps solar for 5 hours = 40 amp/hours per day. Battery is close to 200 amp/hours so 5 days (40ah/day x 5days = 200) but not 100 percent efficient so it takes more.
Those batteries at 11 volts desperately need a charge. Any chance you have a small portable charger just put it on and let it run.
