littlesonny
Dec 01, 2017Explorer
Went to charge the batteries but the charger read fully charged. My volt meter has disappeared so I wasn't able to check with that.
So I found the breaker for the converter. The breaker panel label had "utility - converter." I switched it off. The outlets still worked. Left it plugged into shore power to see if it would overcharge and left it for a day. Seemed okay all day, hovering between 11.8 and 11.9, which gave me hope. Last night I checked it and the panel read EO1, another low voltage warning. This morning I checked it and the error message has disappeared and it reads 11.8 again with shore power still connected. Doh!
I have to run some errands and will post photos of the inverter itself and the battery connections.
