time2roll
Dec 08, 2017Nomad
These black/white bundles are the 120 volts power coming in and going out. The inverter should be labeled which is what or check the manual. Power in should have 120vac. You may need to open up some access panels to get the meter on it. Voltage detector should also work through the insulation.
