allen8106
Dec 13, 2017Explorer
littlesonny wrote:
It has been my experience that sometimes people with experience can inform better than the manual. So... the world's longest question...
According to the manual the Xantrex automatically switches off from inverter mode when shore power is detected and from shore to inverter when shore power is not present. It would appear generally one doesn't have to shut it off when out and about. However, how much does the Xantrex drain from the battery if inverter is left on with no other drain, say when the trailer is in storage? Should one be able to turn on and forget it most of the time, only having to turn off when in storage or some other situation with no shore or no sun for an extended period? Or should the Xantrex be shut off whenever connected to shore power allowing the OEM converter to do it's thing on it's own?
My Magnum MMS2012 will drain about on edit .4 amps if the inverter is left on. I have a remote display that permits me to turn the inverting off when I want to.
All inverters have parasitic drain when inverting and nothing in the camper is turned on.
Very sorry to read about these troubles. I spent a year researching my solar installation and did it all myself for under $2,300 and after fixing a couple minor errors made by me the system worked flawlessly at start up.
I tried to send you a private message on this forum but you have your profile set up to not accept private messages.
