time2roll
Dec 13, 2017Nomad
My Prosine 1800 would still drain the battery a bit when turned off. With just 15 watts solar I had to disconnect the inverter for storage. Now with more solar everything stays connected although I still turn the inverter(GoPower) off.
If your 150 watts of solar gets working, just turning off the inverter should be sufficient. If the inverter is idling (on, no load) it will pull too much from the battery 24/7.
Once you get things wired correctly this stuff will fall into place.
