littlesonny
Dec 14, 2017Explorer
Also, the battery bank is down to well under 12 volts. Should I hook up the trickle charger straight away and get it back up to 14+ before taking the trailer back to the dealer? Should I reconnect the OEM converter at the fuse panel before taking it back? Seems like I might over charge the batteries again if I reconnect the OEM converter which is direct connected to the solar panel.
