dougrainer
Mar 25, 2014Nomad
byronlj wrote:
Wow, I just read your last post. I didn't realize your inverter only had 20amp pass through capabilities (I thought you had 30). That is why it is tripping so easily.
Dave
The post before this has it correct. He HAS 30 amp pass thru power, but it is a dual output Inverter (2 - 20 amp breakers). But as the other poster stated, you CANNOT run MORE than 20 amps on either circuit or the Inverter breaker will trip. I believe that is what the OP is doing---running high amp appliances that total over 20 amps. Doug
