OnaQuest
Mar 25, 2014Explorer
Doug is correct. The transfer switch in the 458 20D is rated at 30amps, BUT that 30amps is shared across the charger, output #1 and output #2. Each of the two outputs is protected by a 20amp breaker. (15/15, 15/20 or 20/20 amp output breakers are options avail.)
The OP is simply overloading the second circuit.
