n7bsn
Sep 04, 2013Explorer
Wayne Dohnal wrote:
Since the purpose of the transfer switch is to operate based on the presence or absence of AC utility power I'd think it's powered by the AC utility power. Since the inverter must be running for the transfer switch to do what you want, it could be powered by the inverter output and/or be a latching relay. Either of these would take some circuitry that would run up the cost. I'd guess it's a simple relay with the coil operated by the AC utility source power.
If by that you mean the relay power comes from the "grid", I can tell you that you are wrong. Since it would not "switch" to inverter, with no "grid" power, and mine does.
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 29, 2026
