n7bsn
Sep 04, 2013Explorer
hmknightnc wrote:
I've never actually test mine to see which source is the preffered source as I have my 2 wired per the manufacture instructions with the remote panel installed. Inverter is always off unless I need it. If no shore power available just turn on inverter remotely and bingo power to the circuits. Never tested it to see which source it chooses if both are available but I believe the device is a normal power seeking electronic ABT. This means it takes it power from what ever source is available and transfers to it. If both sources are available it chooses shore power.
I have, connected to the "grid" with the inverter off, the power comes from the grid (rather obvious).
If I turn on the inverter, while connected to the grid, the power comes from the inverter.
So, when the inverter is on, power comes from the inverter, period. Even if you are still connected to the grid.
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 29, 2026
