time2roll
Oct 25, 2019Nomad
jseyfert3 wrote:Note Trojan really calls for 14.8 volt absorption. 14.4 may require more frequent equalization. And equalization at 16 volts should be done with the RV disconnected as you are above voltage spec on some control boards.
As I understand, this means take to 14.4 volts (bulk), hold at 14.4 V until the current drops to small percent of capacity (absorption).
Having RV issues? Connect with others who have been in your shoes.24,404 PostsLatest Activity: Aug 06, 2026
