BFL13
Oct 25, 2019Explorer II
For $124 you can do it all and do it right instead of not quite all, not quite right for over twice that money.
Easy to use as a portable charger by cutting the end off a set of jumper cables to clamp on with.
https://www.boatandrvaccessories.com/products/powermax-pm3-60lk-12-volts-60-amp-power-converter-battery-charger-w-led-light
Two 105s can take 70 amps but a 2000w gen will struggle with that many amps so go with the 60. (That Trojan 10-13% is for when on shore power and gen time not a problem. Off-grid you do 50-90s and at max amps the batts can take and what the gen can run, whichever limit comes first)
Having RV issues? Connect with others who have been in your shoes.24,404 PostsLatest Activity: Aug 06, 2026
