BFL13
Oct 25, 2019Explorer II
Yes it is a little pot on the side of the circuit board. You can get in trouble trying to mess with that circuit wiring soldering etc, without frying it. Kind of expensive risk /reward. IMO leave it be. It also has some connection to the switch in the other hole in the side.
They used to make one with an external knob that is a lot easier to work with, but this one works too. You don't actually change the voltage very often. I would leave mine at 14.8 and use the OEM converter for any 13.6 mostly.
I have a Trimetric that does my amps etc.
Having RV issues? Connect with others who have been in your shoes.24,404 PostsLatest Activity: Aug 06, 2026
